Dword to 2 words and back
Guest Guest_Mike
I got to fetch and poke data to an FX2n PLC. I'm getting 32 bit register data that I get in terms of 2 signed words (lsw and msw) that I need to put back together as a Dword. I also need to take a Dword and figure out the 2 words that make it and send back to the PLC. It's MX Component and VB6. I got a formula but it does not work if the msw is a negative integer? Any ideas? I need to do the conversion in VB6. Thanks, Mike
I'm not sure I understand it correctly but it should be just a simple bit manipulation like this: Public Function ConvertToDINT(intA As Integer, intB As Integer) As Long Dim intC As Long    If intA < 0 Then intC = 32768    intA = intA And &H7FFF    intC = CLng(intB) * (2 ^ 16) + intC + intA    ConvertToDINT = intC End Function This should combine two 16-bit integers into DINT. Just do the same steps backwards to convert DINT into two INTs.
