alvis Posted September 5, 2014 Report Posted September 5, 2014 hi guys, is that possible to put 2 cclink (QJ61BT11N) in a same CPU module? 1st cclink comunication with - A area 2nd cclink comunication with -B area Good Day =)
JRoss Posted September 5, 2014 Report Posted September 5, 2014 Absolutely. I have a customer with two or three in the same rack.
Crossbow Posted September 5, 2014 Report Posted September 5, 2014 The manual states a limit of 8 CC-Link networks which can be configured via parameters. More can be added than that, but they need code written to configure.
alvis Posted September 8, 2014 Author Report Posted September 8, 2014 (edited) how should i configuration on parameter ? is it same configuration as usual? Edited September 8, 2014 by alvis
JRoss Posted September 8, 2014 Report Posted September 8, 2014 Assuming both are Master cards, then they'll be set up essentially the same way. All the addressing should be different, and the remote stations will likely be different, but you can follow the same format. If the second card is a slave card, then you'll be setting it up accordingly.
alvis Posted September 11, 2014 Author Report Posted September 11, 2014 (edited) is this correct? 1st cc-link = link to 12 nos modules 2nd cc-link = link to 13 nos modules Edited September 11, 2014 by alvis
JRoss Posted September 11, 2014 Report Posted September 11, 2014 Um, yes? Since I don't know what's in your PLC Rack, what's connected to the networks, or what you are trying to accomplish, I'm not sure what kind of response you're expecting.
