Whisper_here Posted September 23, 2014 Report Posted September 23, 2014 I have encountered memory backup battery failure/fully drained in MITSUBISHI A2SH PLC.So RUN LED started flashing on PLC. Thus no field parameters values were being shown on HMI. I connected PC with PLC through serial RS232 cable using GX DEVELOPER 8 , the connection test was successful. Then I tried to download my project saved on PC to PLC, then I was amazed as It asked for a keyword. However when the backup battery was working , I downloaded the same project but it did not ask for any keyword. Can anyone explain this. Now the real problem is that the program was developed by somebody long ago , to whom I don't have any contact right now and I m helpless as I don't know the keyword and can not download the program and thus my machine is at halt. I tried to clear the user memory from online menu , but it says the function not supported. I m stuck and frustrated . Anybody 's help is greatly appraised in anticipation. Of course I m not asking for hacking a keyword. Just to know how can I make my system functional. Thanks everybody. Quote
samuel_12 Posted September 23, 2014 Report Posted September 23, 2014 Dear Whisper , If this is asking the keyword , already it means this is password protected from the old programmer who have created this and you cannot upload as well download the programme. Quote
Theo V Posted September 23, 2014 Report Posted September 23, 2014 Dear Wisperer_here, Maybe your local Mitsubishi distributor in Pakistan can help you out with the password problem. If you do have the PLC ladder program on your computer you can make a printout and re-type the complete program without passwords in it. It is a drastic solution but if it is your last shot just do it. Best regards, Theo V. Quote
Ph-Menjie Posted September 26, 2014 Report Posted September 26, 2014 Hi Whisper_here, If you have the backup program and a spare of A2SHCPU then replace the CPU and download the backup program on it. Please try also to format the program memory of the CPU if possible. Regards, Ph-Menjie Quote
