kurokage Posted September 24, 2014 Report Posted September 24, 2014 using fx3u 80mr/es and fx3u-16ccl-m will connect to 4 remote i/o 16 bit question about i/o map want set 16 bit ry o(remote i/o) to ry 0 (plc) *8~*F isnt recognized as device on fx3u so it`s possible to set like this ? station 1 -> y40-y47, y50-y57 station 2 -> y60-y67, y70-y77 station 3 -> y100-y107, y110-117 ------- thank u Quote
Crossbow Posted September 25, 2014 Report Posted September 25, 2014 Default allocation on the CC-Link network is 32 bits in and 32 bits out. But I am pretty certain you need to write code to read the inputs or write the outputs to/from the module, and so use TO or FROM instructions and can put the data anywhere you like. Quote
kurokage Posted September 30, 2014 Author Report Posted September 30, 2014 u right. found sample program too on manual i read manual hardware on fx3u i can use both fx3u-16ccl-m or fx2n-16ccl-m so what different fx3u-16ccl-m with fx2n-16ccl-m ? basically fx2n = fx3u ? fx3u-16ccl-m = fx2n-16ccl-m ? Quote
Crossbow Posted October 1, 2014 Report Posted October 1, 2014 The FX3U master offers more slaves and CC-Link version 2.0 settings. Quote
