Hi Banker, I am running CX Supv 3.0 with CX Server 5.0 under the Win7Pro_32 bit, problem all the time unable to load the cx supervisor runtime, The problem is, I called up the runtime, and executed only for secs until then was disappeared. There is no even/error reported. Is there any issue with the system of Windows or other programs that blocked it to run from the back end? Thanks
