Im new at this and just need some help. Im using a vision 130 with V130-33-TRA22. I have 1 push button wired in and two lights wired. I need to be able to push the button once and one light comes on then push it again and it turns off. Then push 3rd time and 2nd light comes on then push 4th time and 2nd light turns off. I cant figure this programming for the version 9.5 out. please help me with what to do for the programming.
First you should put this post in the section called "Other PLCs" Then post what you have for version 9.5 and maybe someone can help translate to the newer version.
