alankit Posted November 19, 2014 Report Posted November 19, 2014 Hi guys, i came across this today, I'm wondering how to write a program that reads the values from the AI Module. I've search for leads i found this (FROM/TO) Command. Can anyone explain how to set and take data from this command? Thanks appreciate it...
udhaya Posted November 20, 2014 Report Posted November 20, 2014 Hi Alankit, You can use Gx-configurator-AD for configuring analog modules in Q series that will be very easy...
Crossbow Posted November 20, 2014 Report Posted November 20, 2014 First, what software? Then what version? And what's the actual layout of the hardware on the rack? This will be required to determine the address of the card for TO/FROM instructions. If GX Developer, you can write TO/FROM command to read and write data with special modules. The help file explains this very clearly. You can also use GX Configurator-AD to make it more automatic, if you have purchased it. If you are usng GX Works2, the tool to replace GX Configurator-AD is built in.
