Hi, Please someone help me! I need to make a basic program on a S7-1200 CPU, What I need to do is on input 0 I have a switch & I need need to create a sequence for a Project. When the input is on I need to set output 0 then after ten seconds it will set output 1 then 10 seconds later it will switch off both outputs..... I would like it if someone could upload a screenshot of what I need using function blocks if possible please. Thanks Steve
Hi, Right so I have done that now I need to do another one! This time I need to have three inputs with different timers to start the sequence, I will put 24v on Q1 for example and it will count 30mins before starting the sequence, but it must keep resetting itself!! Just want the best way of doing this! Screen shot would be helpful. Thanks Steve
