Hello touth, you are using wrong cabel or you settings for com-port are wrong - check data bits, stop bits, parity, ASCII/RTU, baud rate. Cabel pins should be (dp9-dp9): 2---------------------------------------------3 3---------------------------------------------2 5---------------------------------------------5 4----| |----4 6----| |----6 7----| |----7 8----| |----8
