gclshortt Posted January 19, 2015 Report Posted January 19, 2015 http://accautomation.ca/now-you-can-have-robust-data-logging-for-free-part-1/ YouTube overview: https://www.youtube.com/watch?v=6Xa2HYVOxE0 Robust PLC Data LoggerWith traditional loggers, software will read the memory of the PLC and store in a local computer. If the network stops or the PLC communication fails then the logging will stop.Creating a robust PLC data logger allows the communication to be stopped for a period of time without losing any of the data for collection. This is accomplished by storing the data locally on the PLC until communication is restored. All of the data is then read without loss. The amount of time that the connection can be lost will be dependent on the memory size of the PLC and the frequency of the data collected.This series will walk you through the steps to create and implement a robust PLC data logger using the following equipment and hardware. Automation Direct – Do-More – H2-DM1E PLC (Ethernet Modbus TCP)Do-more Designer 1.3 (Simulator instead of PLC mentioned above)Windows based computer running IISVisual Basic 6Regards, Garry http://www.accautomation.ca Quote
