FET_Destroyer Posted January 19, 2015 Report Posted January 19, 2015 (edited) Hello guys, I've got a problem that is driving me crazy and I'm prety sure the solution is simple :s So, ive got some strucutres and I'm parsing values from one to the other (same strucutre scheme) in ST language. But if I put all the code in a FOR cicle it give me the error 'Invalid array index'. If instead of an index i put a real value, i've got no error. Can somebody help me with this? what I'm I doeing wrong? -----CODE------ ----DATA TYPES---- ----SYMBOLS----- Regards Edited January 19, 2015 by FET_Destroyer
tashinz Posted January 19, 2015 Report Posted January 19, 2015 Yes, if you use constant instead of symbol index, it will work. If you search cx-programmer help for struct key word you'll get a topic named Structure Symbols, and there you will find the following: Subscripts of Array Data Structures The subscripts must be constants. Symbols, addresses, and formulas cannot be used. I think this is referring to your problem. regards
FET_Destroyer Posted January 19, 2015 Author Report Posted January 19, 2015 Thanks tashinz, I found what you are talking about. Is there any other way to do this? Otherwise I will have to put my FOR cicle into a long code :s
tashinz Posted January 19, 2015 Report Posted January 19, 2015 (edited) Well, Gama_Temporary and Gama_Memory are identical structures. you need only one structure of a kind and then create variables memory and temporary that are types of that structure of yours. then try to simply assign one variable to another, e.g. temporary := memory; I didn't test, I can only see that no error is reported on compiling. the question is if all the data from the structure variable memory is transferred to a temporary structure variable. you should test this. Edited January 19, 2015 by tashinz
tashinz Posted January 19, 2015 Report Posted January 19, 2015 (edited) It works in simulator. And as I can see, now you can use FOR to address a structure variable array, not a member of a structure variable (now you don't need to parse all members to assign values). I've created a simple program (not a FB) in ST: FOR index := 0 TO 4 DO temp_1 := test_1[index]; END_FOR; where temp_1 and test_1 are structure variables. in this example, temp_1 members get values from members of test_1[4], (it works in simulator). regards Edited January 19, 2015 by tashinz
FET_Destroyer Posted January 19, 2015 Author Report Posted January 19, 2015 Thanks tashinz, Another question not completly related with this. I want a array of strings? Is it possible? I simply cannot create an array of strings :s Regards
tashinz Posted January 19, 2015 Report Posted January 19, 2015 indeed, an array of strings is not possible. regards
