I have a project in which I have pulled (2) MR-J2S-10B Servo Amps as well as (2) HC-KFS13 servos out of a previous machine for. I am having problems getting the servo amps to come out of the “AB” state on the display. I have them hooked up to a A1SJHCPU with a A1SD75M2 module in slot 0. Currently I have the program turning on Y1D and Y15 like the A1SD75M2 manual says. I have the A1SD75M2 set as a special 32bit module and no errors on the PLC with the Module displaying IDL. For the control axis switch on the amp I have the first set to 0 and second set to 1. Do you have any ideas on why I cannot get the amps out of “AB”? This is my first time working with servos so i apologize in advance for my ignorance on this subject. Edited by Dot.ss
X0, XA, XB, and XC are all off. For BFM 1179 it is 0 I have not started setting up programming on the second axis but it is hooked up. 1229 is at 0 currently So far i have copied the program from the manual in section 6.4 exactly as it is written. Edited by Dot.ss
I am only using TO commands In section 3.4.2 it says X0 (AD75 READY) turns off when Y1D (PLC READY) turns on For X0 OFF = READY Complete ON = Not ready/WDT error So if i understand correctly X0 should be off? Edited by Dot.ss
