Siemens, free programming software for learning?
Does Siemens have a free version of their programming software that works on anything above WinXP? What I can find refuses to work on anything more capable than WinXP 32bit. Can't use compatibility modes to make it work. Would rather not waste the harddrive space a virtual machine will absorb if I can avoid it. AB/Rockwell has RSLogix MicroLite.
When I first got started, I was able to order a 30-day trial version of Step7 from my distributor for about $30. I would guess that the same would be true of TIA Portal, which is the new package.
Hello Sir, Just give a try, it works for me. for windows 7 64 bits: http://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo?=en&objid=57026339&caller=view for windows 8 64 bits: http://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&objId=68015276&objAction=csOpen&nodeid0=10805384?=en&siteid=cseus&aktprim=0&extranet=standard&viewreg=WW Edited by Jairus
Hey look at that, they do have downloads on their sight. I'm still figuring out how to navigate that thing. Here's the page for TIA Portal v13. There's a Downloads article listed, which unfortunately still says v11 in parts of the article. But the files are for v13. http://is.gd/tWdgWp
Also, I use TIA Portal in a Win7 32-bit virtual machine using VMWare. I occasionally have oddities seeing a processor over Ethernet. Sometimes it works using NAT, sometimes only with bridged. I'm planning to purchase a USB/Ethernet adapter to use in the virtual machine to see if that makes it more better.
