sabertooth Posted January 23, 2015 Report Posted January 23, 2015 Hi....i want to display some data in hyperterminal connected to cp1e plc of omron through RS 232... Anybody knows the code...or could help me in making Quote
Mendon Systems Posted January 23, 2015 Report Posted January 23, 2015 It is possible, but definitely not easy! You will have to format your data as an ASCII string in sequential registers in the CP1E then use a TXD instruction to send the data to the RS-232 port. Quote
