gempetya Posted January 25, 2015 Report Posted January 25, 2015 (edited) Hello! We have a machine with M258 schneider PLC. I already programming mitsu, modicon, omron, siemens... etc PLCs, but this this schneider and somachine is totally different. After a little modification somachine write this message: "The boot application is different than RAM application. Need to update." This update is important? Why need this? Edited January 25, 2015 by gempetya Quote
cHud Posted January 26, 2015 Report Posted January 26, 2015 I havent worked with somachine but presume that you have to update the boot application. Otherwise when the power cycles on the cpu the program loaded will be different to the program changes you made in the ram Quote
gempetya Posted January 26, 2015 Author Report Posted January 26, 2015 Yes, I made PLC restart and modification disappeared. I already set the boot update to automatically in the properties, and now OK. Thanks! Quote
CapinWinky Posted February 20, 2015 Report Posted February 20, 2015 Just the other day I was saying I didn't know why anyone would by a B&R PLC from Schneider instead of B&R. How did you end up with an M258? Quote
