cowboy_glb Posted January 27, 2015 Report Posted January 27, 2015 hi everyone E1101 touch screen be replaced by exter t100 how to convert E-designer project(*.mpa) to information designer project(*.cpa) by the way ,my E-designer version is 7.52, is it the newest version? Quote
djtron Posted January 27, 2015 Report Posted January 27, 2015 E-Designer 7.52 is the latest version avaiable - and I don't believe there will be another release of it. I have never heard about any possibility converting E1000-Project to Exter-Series. In principal both units are exactly the same. But as much as I know, you not able to install the firmware of the E1000-Series on an Exter-Series panel, since BIOS is blocked therefore. Did you check the file content of .mpa and .cpa? I guess easiest way is buying an E1101. Quote
dunc Posted January 27, 2015 Report Posted January 27, 2015 I looked at this before, but was looking to convert from .cpa to .mpa. it doesn't appear like it can be done other than by the oem. beijer have information on their website about conversion, but it is a little vague. im sure they will help if you contact them. beijerinc.com/product/mitsubishi/#mitsubishi-exter 1 Quote
