cltoh77 Posted January 31, 2015 Report Posted January 31, 2015 Hi all, I try to install SoMachine 4.1, after launch SoMachine Configuration Manager, it show all the option is disable (pls refer to attached picture), please advise what is the problem or mistake during installation. Thanks in advance. Quote
cHud Posted February 2, 2015 Report Posted February 2, 2015 There is no picture attached. Make sure after selecting the file that you click on attach this file Quote
MuhteremCayli Posted April 8, 2015 Report Posted April 8, 2015 Bu sure the DVD has inserted already than open the configuration manager after that select customize version and all.You can install all files. Quote
pateldhavalsm Posted April 13, 2016 Report Posted April 13, 2016 Hi All, I'm facing a similar problem. I have Windows 7 Professional 64 bit. I tries formatting my laptop twice but could get a solution. kindly find attached image. I'm logged in as an administrator. Thank you. Quote
PLC_L Posted April 21, 2016 Report Posted April 21, 2016 Try to check and make sure the destination installation path is not too long Quote
mgn Posted August 24, 2016 Report Posted August 24, 2016 (edited) On 4/13/2016 at 11:46 AM, pateldhavalsm said: Hi All, I'm facing a similar problem. I have Windows 7 Professional 64 bit. I tries formatting my laptop twice but could get a solution. kindly find attached image. I'm logged in as an administrator. Thank you. Hi! I'm facing the same problem. Did you manage to solve this problem? Edited August 24, 2016 by mgn Quote
cHud Posted August 26, 2016 Report Posted August 26, 2016 If you have the installation files on disk then i dont know but if you have it on ISO file you have to mount the iso to a virtual drive. Otherwise it wont work during the initial setup 1 Quote
Nalin Posted March 2, 2018 Report Posted March 2, 2018 Hi All, I'm facing a similar problem. I have Windows 8.1 Professional 64 bit. I tries twice but could get a solution. kindly find attached image. I'm logged in as an administrator. Thank you. Quote
cHud Posted March 5, 2018 Report Posted March 5, 2018 Refer to my post. You need to mount the iso file on a virtual drive. Otherwise it wont work 1 Quote
Shukhratullokh Posted March 8, 2018 Report Posted March 8, 2018 as CHUD said above you need to launch ISO after mounting as a virtual drive , if you need any further information contact me via whatsapp +998903373733 Quote
