Angel David Posted February 3, 2015 Report Posted February 3, 2015 Hi there I have a panelview in plant and when I try to buy, it tells me this obsolete, someone will know what is the recommended replacement for this equipment Rockwell, part number is 27711P-T7C4D1 or when i can found this number replacement part thanks a lot guys for the help Angel Leiva Project Manager Ingenieria Autintrol CA 584242608153 Quote
Bering C Sparky Posted February 3, 2015 Report Posted February 3, 2015 (edited) 2711p-ap003_-en-p.pdf I have not used the Panelview Plus 6 so just going by what I found doing a Google Search. This attached Document released April 2014 seems to point to the Panelview Plus 6 as a replacement for the model you list in your post. Although it does not directly list the model you show it does cross ref. the 2711P-T10C4D1 over to a repalcement of 2711P-T10C4D8. Also a Goolge search will pull up a model # of 2711P-T7C4D8 so possibly this is a sutable replacement for what you have. Again I have not used this panel so just going by what I found on the internet, please take what I say here with a grain of salt. If I am wrong in this others will correct me shortly. Good Luck BCS Edited February 3, 2015 by Bering C Sparky Quote
Arlen Jacobs Posted March 6, 2015 Report Posted March 6, 2015 yeah, the replacement is 2711P-T7C4D8 If you are using RIO or DNet communications, then that catalog will not work. Quote
nehpets Posted March 7, 2015 Report Posted March 7, 2015 I would also point out that the software for the panelview plus range is different and will have to be purchased for panelview standard it's Panelbuilder32, for panelview plus it's Factorytalk. Expect a steep learning curve, when they say it's a compatible replacement they are talking physically. The HMI program can be converted easily once you have a little understanding of how its done. Steve Quote
nehpets Posted March 7, 2015 Report Posted March 7, 2015 (edited) Oops it appears that I jumped the gun there a little (note to self, must fully read posts before replying). Steve Edited March 7, 2015 by nehpets Quote
