ct8356 Posted February 4, 2015 Report Posted February 4, 2015 I am aware that I can use a word lamp, set its display address to $SW10, and then on the HMI terminal screen, the image displayed will change depending on the language chosen. BUT when I change the language switch inside CXDesigner, the image shown in the designer area does not change. This is annoying because it means I have to go into "offline test" to check that my translation images (fancy text shown as a bitmap) are correct. Is it possible to make CXDesigner change the image shown, in the designer area, according to the language switch? Quote
