FX3GE to E1000 built in ethernet port.
I need to connect a FX3GE to a E1000 HMI. I can't find a how to for this connection. What driver do I use in the E1000? What setting in the FX3GE? I am assuming I use the FX3U ethernet driver in the E1000? UDP, MC protocol, 5001 host port, IP address of E1000, 5029 destination, setting at the FX end? Can anyone confirm these settings? Edited by Veganic
FX3GE is basically an FX3G with the FX3U-ENET-ADP adapter bus module built in. Check for settings for that, not for the FX3U-ENET module that goes on the right side. I know they were not identical in their capabilities and ports. But I haven't worked with FX3GE.
