JRoss Posted February 8, 2015 Report Posted February 8, 2015 I have a customer with two machines that have TSX17 PLCs on them. I need to back up the programs and eventually convert them to a newer PLC. What programming cable and software do I need? Machine 1 has the following: TSX17 F4002TSXDTF400Machine 2 has the following: TSX17 F4002TSXDSF612Thanks! Quote
Crossbow Posted February 8, 2015 Report Posted February 8, 2015 Old DOS based software and a special programming cable. I have the software but not the cable. I may know someone in NY who has a cable you can borrow. Quote
JRoss Posted February 9, 2015 Author Report Posted February 9, 2015 That would be appreciated! Thanks! Quote
OldPLCProblems Posted April 6, 2018 Report Posted April 6, 2018 Where did you get the software for this? I downloaded software from Schneider (https://www.schneider-electric.com.eg/en/faqs/FA144309/) and ran the install file in vDos but it displays an error of "Fatal Error 251: Your Telemecanique System is incomplete. Ensure that user interface is correctly installed." Is there an user interface software the I am missing? Quote
cHud Posted April 9, 2018 Report Posted April 9, 2018 not sure if it will work in vdos. Need to have windows95 or 98 installed on a virtual machine the use that dos Quote
Crossbow Posted April 13, 2018 Report Posted April 13, 2018 There are multiple software packages, PL7-2 and User Interface. One cannot run without the other. Quote
