Stuartjl Posted February 25, 2015 Report Posted February 25, 2015 Hi, I have the above PLC. That I need to put the MBOC on. Currently the PLC has nearly been commissioned, so it has PLC code, setpoint etc. I will save these. When I format the drive on the PLC for MBOC will I need the standard red serial cable for downloading to the PLC or will my Ethernet connection still work? Stu Quote
kaare_t Posted February 25, 2015 Report Posted February 25, 2015 If you power off the PLC after formatting the drive, I'm pretty sure that the Eth card will reset to default. So I would, just to be sure, bring the red serial cable. Quote
Stuartjl Posted February 25, 2015 Author Report Posted February 25, 2015 (edited) Thanks kaare_t thats exactly what I needed to know. Edited February 25, 2015 by Stuartjl Quote
