How do I add a subroutine in GX-DEV?
This only applies to QnA & Qn processors, you cannot have multiple program files in A or FX: Expand "Program" in the project manager tree Right click on "main" select "new" Enter the name of the new program file in "data name" Select whether Ladder or SFC in "program type" Open the PLC parameter dialog and select the "program" tab Insert each program in the order you want and select the execution type, i.e. scan, low speed, wait etc. To create a subroutine in a single program file, you will need the "Call" command to call a subrotine which lives between the FEND and END instructions. Call commands use a reference pointer, such as P1000 for example.
