FET_Destroyer Posted March 5, 2015 Report Posted March 5, 2015 Hi guys, I'm working on a project that use a NS8 hmi and 3 CJ2M cpus. All the system is connected by ethernet. My question is, if one PLC is offline, without power, a popup message continues to appear always on the hmi. Is it possible to delay for a loooooooong time or even disable the connection timeout error? I change all the settings related to communication and still the warning continues. Regards Quote
PdL Posted March 25, 2015 Report Posted March 25, 2015 Try setting Comms auto return to ON. Still, when any of the NS host goes offline, it becomes so slow to operate that it is almost unusable. Quote
FET_Destroyer Posted March 25, 2015 Author Report Posted March 25, 2015 Hi PdL, I think I did that, I'm not sure, It was some time ago, I changed all the fields, and the error was still poping. I will give a try again only with that field OFF. Thanks Quote
