Ben'z Posted March 11, 2015 Report Posted March 11, 2015 I have to try connect plc FX3U with android. In play store, I found modbusdroid app.This app can communicate with PLC using modbus protocol. I already configure Enet-L module like this : Maybe someone can help me? or already try modbusdroid app and success connect with FX3U? Thanx for your advice. Regard Ben Quote
kaare_t Posted March 11, 2015 Report Posted March 11, 2015 You will need FX3U-ENET-P502 to open for ModbusPort 502. Alternatively if you can change the default port number in Android, you could use the standard Eth module on the FX. Further, which software and language are you using? Quote
Ben'z Posted March 11, 2015 Author Report Posted March 11, 2015 can't only Enet-L module? I see in youtube, only use Enet-L module but using gxwork2.. I use Gx Developer.. Or maybe need ladder plc? In modbusdroid can change port number. what do you mean with Software and language? Quote
kaare_t Posted March 11, 2015 Report Posted March 11, 2015 I'm not familiar with the ENET-L module, is it a left-side module? Quote
kaare_t Posted March 11, 2015 Report Posted March 11, 2015 OK, found the ENET-L module. First; I don't think there's any GX Developer examples or functionblocks for ModbusTCP. In other words; you must program the protocol yourself (the specifications for the application layer can be found on the internet). Alternatively you can use GX IEC Developer, or GXWorks2 using Structured Ladder and use the function block from Mitsubishi. That's a functionblock which implements the IN/OUT's you need to use the ModbusTCP protocol. Quote
Ben'z Posted March 12, 2015 Author Report Posted March 12, 2015 kaare_t, now I try install GXWorks 2. FX3U-Enet-L is special Module right? I add new module but FX3U-Enet-L not available Can explain me how to add module in GXWork2? Quote
Gambit Posted March 12, 2015 Report Posted March 12, 2015 https://play.google.com/store/apps/details?id=be.bitmetric.datavizor.android&hl=nl uses the FX protocol Quote
kaare_t Posted March 12, 2015 Report Posted March 12, 2015 @Gambit: Nice if that exists, however the link does not work... Repost? Quote
Gambit Posted March 12, 2015 Report Posted March 12, 2015 Strange works for me: https://play.google.com/store/apps/details?id=be.bitmetric.datavizor.android&hl=nl Quote
kaare_t Posted March 12, 2015 Report Posted March 12, 2015 @Gambit: Doesn't work in Norway... Tried searching too but without luck (automatically redirected to Norwegian GooglePlay website)... @Ben'z: You don't add the special module. You need FX Configurator EN to configure the ENET module (same as in GX Developer). Then, as Gambit proposes, use the Android app to communicate directly with the PLC using the FX protocol. Better than to use Modbus in between... Quote
