GX IEC Developer 7.04 crashes when scrolling..
Maybe a bit late but I recently had the same problem and solved it:
The last change after crashing I made was adding a pin (VAR_INPUT) to an FB, instead of inserting it after all the inputs, I added it at the end of my FB header.
Steps I take to solve:
Insert the pin after the inputs, and delete the old
Take an export of the global vars, open it with notepad
In my case the pin was added for some reason somewhere between the VAR_GLOBAL, delete it
Import the global VAR  list
Edited by Maikel
