Hi all, I'm using S7 graph and I would like to be able to jump to a step after a warm restart of the PLC. This is to be able to carry on from the step the sequence was in before the restart. I have figured out that I can select a step in Manual mode. So if during the warm restart I pulse a bit for the input to SW_MAN then Load an INT value representing the S_NO before the restart into S_SEL and then pulse another bit into SW_AUTO. Will the sequencer carry on like normal in auto mode from the selected step?
