gruka Posted March 19, 2015 Report Posted March 19, 2015 May someone give the simple wiring cable diagram to program Mitsubishi FX2-CPU Jy331A57001C board with Gx Developer software , i would appreciate if you may as well give in details which files to load first cause the machine stops cause of the battery failure. Below is the picture of the module to be programmed.
kaare_t Posted March 20, 2015 Report Posted March 20, 2015 First of all the board does not have to be removed to be able to program it. Second you will need the SC-09 (red) cable to program it. Third, in GX Developer just download the project as normally. Fourth, replace the battery. 1
