Antagor Posted April 7, 2015 Report Posted April 7, 2015 Hi all, I have a new problem. I have to translate NT631C application from Dutch to English(or Serbian). I uploaded *.mmi language file with translation utility and start translation but now I want to "merge" new mmi file with onw file(application) to see how new language looks like before downloading it to the touch terminal. Is this possible or I have to download new mmi to touch and then upload whole application again? P.S. Touch is on site 100km from my office. Quote
PdL Posted April 7, 2015 Report Posted April 7, 2015 Hi I must admit I have never used the translation utility with NT touchscreens. Have you read the manual? I had a quick look and as I understand, in the end you generate a language specific *.mmi file where the selected language is already processed in all strings etc? Can't you just open this *.mmi file in NTST? Appendix D - Translation Support Utility.pdf Quote
Antagor Posted April 7, 2015 Author Report Posted April 7, 2015 Uh, I understand I have to do it as it says at the beginning of pdf you send, manually. Actually it worked but I don't understand. If open *.mmi file with NTST how it opens screens if they are in onw file??? Never mind, important that it works. Now I need you only to translate me few sentences from dutch to english Navriezer Voorvriezer Quote
