Hello. In future You should really tell us which hardware and which software you are using. But I guess you are using GX IEC Developer? you should be able to jump to the error. There should be something in RED indicating where the missing line is. It might be the case that you have two lines overlapping but only one is connected. This could also cause this error. If this is the case you should delete the line and you will see the unconnected line.
Hello. Sorry. GX IEC Developer. The plc is FX1S There is red indication in the missing line. But I can,t find anything that is wrong. I have done all connections again. Still the same problem.
Is it an existing project??. If not you should use GX Works instead of IEC Developer unless you are still using an old A series PLC. If you have any other question please post them. Isn't there a new Mitsubishi branch in Sweden. They should have support
