valsidalv Posted April 15, 2015 Report Posted April 15, 2015 Hi, I am very new to Mitsu PLC but have spent some time with Allen-Bradley and Beckhoff. I received an older Q series PLC at work with a Q02 CPU and a few cards. One card is the mixed input/output QX48Y57. It has been wired up with an input switch and output LED but I am unable to detect any input or force any output using GX Developer v8.102G. Adding to the issue, I cannot even detect a serial number for the card through the Diagnostics > System Monitor dialogue. Attached is a screenshot of the "Product Information List" window. It is able to see the card but no serial. I am wondering if this might contribute to my problem of not being able to toggle any I/O. Any help is appreciated. Thanks! Quote
Akahige Posted April 15, 2015 Report Posted April 15, 2015 I have noticed that this issue continues into the GX Works2 programming software. The serial numbers start with 4 or 5 digits but the rest are all zeros (0). The first four digits are to represent when that module was produced. Though even with the lack of this information I have not run into toggle I/O issues. Quote
valsidalv Posted April 16, 2015 Author Report Posted April 16, 2015 If you look at my screenshot you'll see that the QX48Y57 module has no serial at all, just a dash "-". At least the other cards display something, so I'm wondering if that's an issue. Also can someone clarify which outputs I should be firing? Is it simply X0, or is there some identifier that GX Dev uses to find the correct card? Quote
Crossbow Posted April 17, 2015 Report Posted April 17, 2015 Discrete I/O cards do NOT have serial numbers. And the serial numbers on the intelligent modules are a date code and all zeros. What you are seeing is absolutely correct. Quote
