Hello all, It's been a while since my last post and this one might be a bit vague. I'm pretty new to Mitsubishi, we are still,using IEC developer from I think v6 to v7.04. There are limits to online edits regarding the CPU memory, can these be overcome with a memory card? Can this be used just for the edits then removed from the CPU? Thanks in advance.
If you are using a system Q PLC then yes instead of online change you can do an online program exchange instead. You can do this if your program is half the size of the CPU or if you have a memory card installed.
