manowar Posted April 28, 2015 Report Posted April 28, 2015 Hello. I have switched from NT2-ST software to NTXS. Now I'm having one small problem. In old software (NT2-ST) I had special screen called LOOP. You defined screens in this LOOP and the display would stay in this loop (using buttons NEXT/PREV) In newer software (NTXS) I can't find anything similar. Do I have to make LOOPS inside PLC to modify STR register? Or define a BUTTON Function on EVERY SCREEN? This would make a nightmare. Thanks. Best regards. Quote
manowar Posted April 28, 2015 Author Report Posted April 28, 2015 OK. I have figured out. You have to do it manually. At the last screen you add function to NEXT button (go to first screen in a LOOP) At the first screen you add function to PREV button (go to last screen in a LOOP). Best regards. Quote
