Hello experts; Good day. I have series 90-30 hardware. The cpu family is 350. I used LM 90-30 Dos based software. Now i want to use windows based software which can be program GE fanuc series 90-30. In LM 90-30 the %R creates very ambiguity. Some body told me that versa pro have the capability to show the next free register while you programmed. Can any one suggest me where from i download the trial version to check and test the software with cpu 350. Then i want to purchase it for single user. If any body knows the price please pass the information. Thanks
VersaPro is also obsolete software. The current offering is called Proficy Machine Edition. If you want to use the next available register when making changes to an existing program, simply type in %R without any numeric characters. Logicmaster will select the next available %R address. The same technique works for any memory type (%I, %M, %Q, etc). Logicmaster only keeps track of the highest used address for each memory type. Thus, if the existing program uses %R00001 through %R00050 and also %R00100, as far as Logicmaster is concerned the next available address is %R00101, even though %R00051 through %R00099 are also available.
Respected friends; Good day. I ask the local GE distributor they give me price of 4500 us dollar of PME with cable. They also told me that we have no versa pro Trial CD. For my project the PME is so costly, Is there any help me to send me Versa Pro trial version? Can Versa MAX also program the 90-30 series CPU 350 family. I also want to ask that this is an excellent forum for the control engineer. But i am also regular user of PLCTALK.net but from the 6 to 7 month when i open i saw always one message FORUM IS UNDER MAINTENANCE. I tried with different types of browser like fire fox, IE, google chorome etc, I also send a lot of message to the admin but never receive any reply. I have about above 200 posts on that site. Can any one guide me how i fix it? I live in Pakistan ASIA. Regards
It sounds like your supplier gave you a price for the "LD PLC Professional", ask for Proficy Logic Developer PLC Standard instead. Get a demo DVD of Proficy ME from them too or call GEIP for one, it will run for 4 days after each install of the software. GE-IP can also give you a 30 day trial license, after you get the Demo DVD and install the software call them: http://support.ge-ip.com/support/index?page=spage&id=ST6&locale=en-US&locale=en_US Try this link: http://www.plcs.net/ Or: http://www.plctalk.net/qanda/ Edited by RussB
  • Like 1
i am also facing same proble..
I give you the same answer:
