blackd Posted May 1, 2015 Report Posted May 1, 2015 I am having problems connecting a Q170MSCPU to GOT GT1662V over Ethernet, via HUB. I have been using the Q170MCPU having no problems, but when I change to the Q170MSCPU to use J4 servo's, I have been unable to view or write to the Q170MSCPU module from the GOT. The strange thing is, I can connect to the PLC with no problems. Quote
Gambit Posted May 6, 2015 Report Posted May 6, 2015 This could then only be the CPU number chosen. Which one did you choose for the motion part of the Q170MSCPU. Quote
