Hi all: I want to know when the pls2 command has finished to send the pulses. Is there a flag (Axxx.xx) that tells me when it has finished. I had not found any in the manuals I have. Thank you for your help!
It is right there in the manual!! A280.03 = Pulse Output 0 Output Completed Flag = ON when the number of output pulses set with the PULS(886) or PLS2(887) instruction has been output through pulse output 0. Cleared when operation starts or stops. OFF: Output not completed. ON: Output completed. A281.03 = Pulse Output 1 Output Completed Flag = ON when the number of output pulses set with the PULS(886) or PLS2(887) instruction has been output through pulse output 1. Cleared when operation starts or stops. OFF: Output not completed. ON: Output completed. Edited by BITS N BYTES
  • Like 1
