Owain Posted May 6, 2015 Report Posted May 6, 2015 Hi, I was wondering if it was possible to have 2 HMI's on the same network, independently accessible via Remote Access Viewer? There is a static IP set up on site, let's say 80.80.80.80, with two Beijers E1101 HMIs, one on say 192.168.1.160 and the other on 192.168.1.161. I can view each independently via web browser by using 80.80.80.80:5900 or 80.80.80.80:5901 and setting up port forwarding within the router. When it comes to remote access viewer I don't have the option to specify a port, and therefore can't set up port forwarding, it seems to be fixed to port 5800. Does anyone know of a workaround so I can use Remote Access Viewer to view each HMI independently and remotely. Unfortunately setting up another router and paying for a static IP isn't an option. Quote
kaare_t Posted May 8, 2015 Report Posted May 8, 2015 To change the port settings in the VNC client you should use a viewer with that option. Try e.g. RealVNC or something that allows you to manually change the port number. Further, set up port forwarding in the router so that different ports points to different IP's in your internal network. Quote
