Paul_M Posted May 6, 2015 Report Posted May 6, 2015 First post on here, I have done some searching and can't find an answer to my problem. I'm trying to start a project in GT Works 3 V1.19, with a 7" HMI (Part No GS2107-WTBD), there is no option to use this HMI in the software. I originally assumed I was using outdated software, after visiting 'my mitsubishi' i found I am using the most current version. So my next line of thought was, that because this is a fairly new released HMI that I must just have to download a GSD file, after searching the Mitsubishi download section, I couldn't find anything there either. Am I missing something obvious? Quote
Gambit Posted May 7, 2015 Report Posted May 7, 2015 You need to run an extra installer to be able to chokes these types. GS.exe or something simular. It is on your install dvd I think in the folder tools. 2 Quote
Paul_M Posted May 7, 2015 Author Report Posted May 7, 2015 Hi Gambit, I found the GS installer.exe. It ran, and states: "GS series has become available for GT Designer 3 (GOT 2000) and for the data transfer. I then open GT Designer, I still can't choose a GS series HMI from the drop down menu. 1 Quote
Paul_M Posted May 7, 2015 Author Report Posted May 7, 2015 Problem solved, completely uninstalled GT Developer, then ran the GS installer.exe. I can now choose that HMI as an option. Thanks for the help. 1 Quote
