I've created a project for the above HMI in GT designer 3, it's created a .gt32 file. This file is not recognized by the Melsoft Navigator program, is there something I need to download to get it to be recognized? I ask because I'm not sure how to set up comms between the HMI and the current PLC I'm using (FX3GE). I'm using GX works 2 to program the PLC. Is there a way of setting comms between the HMI thorough GT designer and GX works without using melsoft navigator?
Of coarse you can set all setting directly in GT designer. The navigator just makes the settings for you. If you would like to use the navigator you should save the project as a workspace. You'll then be able to link the project.
