There are five steps installation, wiring and inspection of Delta HMI DOP-B03S210. Before using this delta product, please read the DOP-B03S210 instruction sheet to ensure correct use. You should thoroughly understand all safety precautions before proceeding with the installation, wiring and operation. Please observe the following precautions: 1. Install the product in a clean and dry location free from corrosive and inflammable gases or liquids. 2. Ensure that all wiring instructions and recommendations are followed. 3. Ensure that HMI is correctly connected to a ground. The grounding method must comply with the electrical standard of the country (Please refer to NFPA 70: National Electrical Code, 2005 Ed.). 4. Do not disassemble HMI, modify or remove wiring when power is applied to HMI. 5. Do not touch the power supply during operation. Otherwise, it may cause electric shock. If you have any questions during operation, you can contact us customer service. You also can download DOP-B03S210 PDF Format from FastToBuy.com DOP-B03S210.pdf
