Beause Siemens TD200 has been discontinued,I still need to use some of the machinery.I nedd td200 alternatives.Can anyone tell me what the product can replace TD200?TD200 alternatives need not be Siemens brand, but you can replace the TD200 and the complete program without modification S7200PLC and need CE and UL. I found VIPA TD 03 Text Display but I'm not sure whether you can replace the TD200?
I had encountered the same problem like this before. You can still purchase TD200, it is still available for now, only it's 5X the original price. Or you can use other HMI as long as it is compatible with the s7-200, but you have to know the tag addresses and you need the HMI software. I have winCC flexible 2008, so in my case i replaced it with tp177b 4" touch screen, add some additional feature and it was more good than the original td200, my client really appreciated it. You can do the same thing only if you like. It took me 3 days to finished that project including commissioning.
