mick lovell Posted June 2, 2015 Report Posted June 2, 2015 Hi, We have had some work done to uprate our Hmi and replaced some machinery graphics with new detail. Unfortunately now when we load the screen to the unit it loads the graphics and screen freezes with the following error: System Fill Overflow 447,271 (Enter restart) - pressing enter just cycles back to the same point... the only way to get it too load is to put the old program back in....any ideas , is this perhaps related to the amount of memory??? Regards, Mick. Quote
Ron_S Posted June 2, 2015 Report Posted June 2, 2015 I suspect the 447, 271 is the coordinates of a pixel on the hmi screen. In E designer you can see the coordinates of the screen as you move the mouse around (bottom left corner) Check what is on that particular pixel and try moving it or removing it. Quote
dunc Posted June 4, 2015 Report Posted June 4, 2015 if you run a test on the project before sending does it throw up any errors? Quote
Nightfly Posted June 4, 2015 Report Posted June 4, 2015 It could be that the program is using a digital or analog "Fill" object that fills in a "framed" area with a certain colour. if the "Fill" object is not totally enclosed (it has no frame area to fill only the entire screen or there is an small gap where it can bleed out) then this might give such an error. Quote
