sh3ro Posted June 5, 2015 Report Posted June 5, 2015 hi everybody ; 1-i want to connect m340 with hmi (gto) via ethernet and i want to set adress of the (m340) in the vijeo designer but i don't know which protocol of these i can use and how to set the adresses does anyone has a pictured pdf for which protocol to choose 2- do i need to download (run time installer) to the target(hmi) before i download to it or it is already downloaded to the gto automatically . Quote
Quant Posted June 9, 2015 Report Posted June 9, 2015 (edited) Hello sh3ro, 1) Modbus TCP/IP on your screenshot is the right protocoll. After that you need define the IP address of your plc and from HMI. 2) first time VJD download firmware and runtime to your HMI automatically Edited June 9, 2015 by Quant Quote
