New laptop - HP Omen (gaming machine) - powerhouse - really fast. I always set my laptop up to Syswin short cuts and then program my own shortcuts as well. I normally use for example Ctrl page down for insertion of a rung below - works on my desktop with Windows 7 x 64 bit fine. Does not work on the laptop with Windos 8.1. I have even tried running CX-P in Windows 7 compatibility mode and they still do not work. The standard Syswin shortcuts such as F2 for an N/O contact do work though. Totally puzzled - any ideas? Edited by BobB
Everything works OK except the shortcut keys that I have programmed myself. Will try a new installation but I do doubt that is the problem because everything else is fine. Network Configurator, CX-D, Protocol Macro, routing - all works OK.
