alvis Posted June 20, 2015 Report Posted June 20, 2015 (edited) Dear all I have some problem with this para error 3106. Please help me ...thanks Edited June 20, 2015 by alvis Quote
panic mode Posted June 20, 2015 Report Posted June 20, 2015 as stated in the message info, your configuration is wrong and you need to adjust used device range(s). for example if your PLC has memory that covers data D0000-D9070, but your CC link configuration is trying to use D9010-D9090 you are obviously trying to use not available memory and PLC complains with above message... 1 Quote
alvis Posted June 21, 2015 Author Report Posted June 21, 2015 Thx for your reply.is it i need to put a memory card or i need to move the data from d9010-d9090 to d1000-d9070? Quote
panic mode Posted June 21, 2015 Report Posted June 21, 2015 you need to make sure whatever your CC-link configuration uses is available in PLC/ Quote
alvis Posted June 21, 2015 Author Report Posted June 21, 2015 (edited) Q03UDCPU,QJ61BT11,QX42,QY42P,QY41 connect to 8 station(AJ65SBTB1-32DT) I cant found the problem .... Is there any diffrent between Q00CPU and Q03UDCPU? last few project im using Q00CPU , and i dint face this Problem ...... Edited June 21, 2015 by alvis Quote
Gambit Posted June 22, 2015 Report Posted June 22, 2015 You are using R100. Have you created a Fileregister file in your plc parameters ? And If so did you download this file into your CPU? Quote
