liorganor Posted June 28, 2015 Report Posted June 28, 2015 I am trying to read integer and real variables from Schneider Momentum to XBTGT2130 with an Ethernet cable, and i just can't anything. Does anyone had this problem before?
cHud Posted June 29, 2015 Report Posted June 29, 2015 You need to give a lot more detail. What driver are you using on the xbtgt? Do you have the vijeo designer project? Can you connect to the momentum on ethernet? Can you download to the xbtgt on ethernet?
Quant Posted June 29, 2015 Report Posted June 29, 2015 1) check ip adresses 2) check comm driver in VijeoDesigner
