dunc Posted July 1, 2015 Report Posted July 1, 2015 is this possible and if so, how would I go about it? thanks Duncan Quote
Bryll Posted July 1, 2015 Report Posted July 1, 2015 (edited) Some library FNC/FB names might differ between GX IEC and GX Works Edited July 1, 2015 by Bryll Quote
dunc Posted July 2, 2015 Author Report Posted July 2, 2015 thanks for the info. managed to open it but after compiling has loads of errors that need working through to get it to compile correctly. will have to tell the project engineer he should have specced the job correctly in the first place. Quote
