JManes Posted July 1, 2015 Report Posted July 1, 2015 Good Evening, I am recovering from a catastrophic failure. My Fanuc PowerMate has been received and reinstalled after we had the motherboard replaced. I can not get the IO Link on JD1A1 to start. The other end of this is connected to a interface module. When I move the cable on the Powermate side to a JD1A connection, the IO link starts up. However I do need the JD1A1 to function. Are there any parameters in the PowerMate that have to do with JD1A1? Any advice is appreciated. Best Regards Joe Manes Quote
