jcvel Posted July 10, 2015 Report Posted July 10, 2015 Hi guys: I have come across some bugs with Brick PLC's. I understand things happening in the programming world, but can't accept the fact that after submitting the bugs to AutomationDirect for almost a year nothing has been made to resolve them.... Same firmware version still. I wonder if anyone knows what is the fate of the Bricks ? AutomationDirect service is good, but doesn't seem well supported by Koyo. Thanks JC
TimWilborne Posted July 10, 2015 Report Posted July 10, 2015 Can you explain the bugs you are speaking of so we can be aware of them?
b_carlton Posted July 16, 2015 Report Posted July 16, 2015 Since thee original poster has not returned with specifics of the claims (bugs or 'non-response') then I think we can safely ignore this thread.
TimWilborne Posted July 16, 2015 Report Posted July 16, 2015 Yes I've always gotten quick responses to support questions from them.
rlp122 Posted July 17, 2015 Report Posted July 17, 2015 (edited) 1. Sometimes 'bugs' are working as intended. Working as intended is not always how the user wants something to work however. Corollary; sometimes 'bugs' are considered 'features' by users and taken advantage of in code. When this 'bug' gets fixed it really upsets some folks apple carts. There is a delicate balance of what to 'fix' and what to leave alone. 2. In most companies that I have dealt with, minor issues or complaints don't get addressed until: a. There are enough of them to warrant a separate build, something which is very time consuming due to testing, deployment, etc. b. Something major comes up that warrants all of the labor that goes into a new software build. While almost everyone thinks they want issues addressed as soon as they pop up, I have met not one single person who wants to update software/firmware nearly every day or even every week for that matter regardless of what is 'fixed'. 3. Occasionally an issue just isn't something that can be dealt with easily. In the past I have ran into issues that required years of rework to fix. Obviously this is the exception rather than the rule, but long story short; things take a lot longer in the software/firmware world than we would like for them to take at times. Tangent on the testing, deployment, etc. There is a lot more to this than most lay people realize. It can take weeks to months to drop a new piece of software or firmware depending on what was changed or modified. Having seen firsthand a PLC software/firmware test suite; the amount of code and hardware required for testing a PLC software/firmware release is staggering. The kicker is that every time an error is found, it has to be fixed and the test suite re-ran from the top again. Considering that I was told that one (there are many) of the modules in this test suite took 3 days to run; well... you get the picture. Edited July 17, 2015 by rlp122 1
