i need to upgrade a control system that has a symax m50 plc in it and i do not have a copy of the program... the m50 was a small standalone variation of the symax that was rackless and all the io is onboard (similar to a twido only much bigger and much older).. there doesnt seem to be much info on the m50 and from what i have been able to gather it did not use the same software as the rack style symax.. any info would be greatly appreciated. thanks bigdave
Don't think it even offered software. Think it was a handheld programmer. You might also want to check with Idec as they made all those low end Square D PLCs.
